How to convert .mdl code to R code
dannycantley
Newbie
Vensim version: Ventity
Post by dannycantley »
Hello, How to convert .mdl code to R code? I have searched many places but have not found a suitable solution. Thanks.
Re: How to convert .mdl code to R code
Travis
Post by Travis »
ReadSDR is a good suggestion.
An alternative that is likely more complicated would be to use SDEverywhere [https://sdeverywhere.org] to convert to C code. I'm pretty sure you can call C code from R. Or SDEverywhere also has the ability to run models from a command line (Terminal), which you might be able to use.
We've thought about adding the ability for SDE to output R code directly. If anyone is interested in helping with that, please post on the SDE GitHub discussion forum.
[https://github.com/climateinteractive/S ... iscussions]
