On Vensim 10.2.2(MC) and macOS 15.2, if a Custom Graph exists in a view, after a text field is opened (for example when typing a new variable name or a comment), the keyboard shortcuts for navigating through different tools stop working. To replicate:
1. Open a new model.
2. Add a variable, call it 'test', and hit return.
3. Create a custom graph for that variable and place it in the view.
4. Add a new variable, call it 'test2', and hit return.
5. Without any further click, try to switch to any other tools using keyboard shortcuts.
Keyboard shortcuts will be reactivated if you click on the active window, but it's not supposed to be like this. Shortcuts work as expected on Windows or previous versions of Vensim on macOS.
Keyboard shortcuts bug on macOS
Re: Keyboard shortcuts bug on macOS
Do you mean older versions of Vensim work on MacOS 15.2, or they work on older versions of MacOS?aliakhavan89 wrote: ↑Fri Dec 20, 2024 4:59 pmShortcuts work as expected on Windows or previous versions of Vensim on macOS.
older versions of Vensim work on any version of macOS, as far as I remember. did you have a chance to replicate the issue?
This is working fine for me.
