CIN Files and Sensitivity Analysis
If a model throws overflow errors during sensitivity analysis, does Vensim generate CIN files for the set of parameters responsible for the overflow?
Re: CIN Files and Sensitivity Analysis
No. I could add that in easily enough though (so will ticket it so it gets done).
Thank you so much for your quick response! It's good to know, and it would be great to have it in the future versions. Thanks again.
Do you or anyone have any suggestions on how to find the problematic parameter settings?
Thanks a lot!
I think if you export the results at final time only, you'll find rows that have parameters but not variable values.
Thanks a lot, Tom! This is a great suggestion. I guess I can write a script to look for those variables that don't have any data and extract the parameters in a CIN like style so that I can explore the error. Thanks again!
Hopefully my "think" is correct. In any case we can add it quickly. If you're stumped, and need an immediate result, we could take a look in the debugger.
Thank you so much, Tom. I already had a code and just updated it further (with the help of one of these LLMs) to save the cin files. The core idea was the one you mentioned, which is keeping track of variables that don't have data at the final point of the time.
I'm sharing the code in case anyone wants to use it. The data should be printed with time going down (like the screenshot attached). Also, the model had 5 variables of interest in the save list file.
Screenshot 2025-03-07 at 1.04.31 PM.png (1.26 MiB) Viewed 4462 times
Printing Interesting True Params v02.py.zip
(2.58 KiB) Downloaded 119 times
It also exports all CIN files separately.
Screenshot 2025-03-07 at 1.07.31 PM.png (175.16 KiB) Viewed 4462 times
