Help with SVG Export
Hello, could you please help me properly export the svg of the attached model so that all variables appear in the final product?
Here are some of failed attempts:
Screenshot 2025-03-12 at 12.30.12 PM.png (83.33 KiB) Viewed 4976 times
Screenshot 2025-03-12 at 12.30.25 PM.png (185.85 KiB) Viewed 4976 times
Failed attemps with Model.zip
(43.31 KiB) Downloaded 335 times
Re: Help with SVG Export
You might try opening them in Inkscape (open source SVG-based vector image editor) to see if there's a clipping rectangle or something that is interfering.
Thank you, Tom. I found another workaround a few minutes ago, but I'll keep Inkscape in mind.
For what it's worth, here's the workaround: I had a hidden variable, and when I dragged it outside of the area of the current variables, I think it somehow expanded the printable area. Thanks again for the suggestions.
This should be fixed in the 10.3 release.
Thank you so much! 10.3.0 works perfectly now! Lot's of great features!
Screenshot 2025-03-13 at 9.59.07 AM.png (978.18 KiB) Viewed 4831 times
