Equation Editor not showing up on 10.3.0 on Mac
Equation editor seems to get activated but nothing shows up
Screenshot 2025-03-13 at 9.39.27 AM.png (1.07 MiB) Viewed 6462 times
Re: Equation Editor not showing up on 10.3.0 on Mac
Can you try moving the main Vensim window to see if it's underneath it? It should not be, but I'd like to check.
And are you using multiple monitors?
Of course, I had done that. I only had two monitors connected and was suspecting the extra displays are acting up. They did not. Just a FYI, I have a 14-inch Mac. I can restart it to see what happens.
Is it possible that some interface settings from the previous version in the shared folder are interfering?
When the equation editor was open (and it was not showing up), I changed the resolution and it suddenly appeared!
Screenshot 2025-03-13 at 9.52.11 AM.png (1.78 MiB) Viewed 6448 times
And it now appears in the default resolution. I guess for the very first time it was outside of the display area (all displays).
Screenshot 2025-03-13 at 9.55.20 AM.png (1.19 MiB) Viewed 6448 times
it's all set now. Thank you!
Strange. I'll have to temporarily remove the release until I can find out why this has happened. Same thing happens on my M1 Air, and the Intel installer is not showing the licence agreement for some reason.
Back to building on a 10 year old Mac.
