Hi all,
I would like to add a tooltip in a Comment, so that when I hover the mouse over the comment I can read a specific text.
My aim is to use the comment to draw Loop symbols (+ or -) and then write in the tooltip a short sentence summarizing what the loop is doing.
As you can see from the screenshot, the tooltip field in the Comment window is greyed out. I am using Vensim PLE 10.2.2 on MacOS 12.7
Is that an expected limitation ?
Ismael
Comment's tooltip
Comment's tooltip
- Capture d’écran 2025-03-23 à 15.55.14.png (161.93 KiB) Viewed 1251 times
Re: Comment's tooltip
I've ticketed this internally so we will look at adding them.
