Units reporting errors
Hi all, I would like to ask if the unit of a variable affects the output? For example, the units of the left and right sides of the equation do not match, causing the unit check to report an error
Re: Units reporting errors
No, it does not change the calculation. But units errors should be fixed, they indicate an error in logic in your equations.
This is why they are important, https://www.bbc.co.uk/news/magazine-27509559
