Hi!
I'm using the GUI-objects to create an interface so other people can use my model (via de Model Reader).
With buttons I want to be able to start a simulation and end a simulation. I would like to use Synthesim, so people can change things in the simulation. I found the button command to start the synthesim (MENU>SYNTHESIM|O) and stop the simulation (SPECIAL>STOPSIM|SAVE).
However, I think the synthesim is not available in the Model Reader?
Is there another command I can use with for the same purpose but that is available in the Model Reader as well?
Thank you!
Button command searched
Re: Button command searched
SyntheSim is available in the model reader.
