connectors to vars scrolled to not possible
Posted: Wed May 28, 2025 7:47 am
When models get large and esp. when working on a small screen (e.g. laptop), I noticed that it's not possible to draw a connector by clicking one variable than scrolling until a second variable becomes visible and then clicking that one. Instead I need to zoom out until both variables are visible and then connect them. The problem is that at that zoom level the variables are no longer readable on a low-res screen.
You can simulate this problem even on better screens if you zoom in a lot, so that your target variable is outside of the visible part of the model.
It would be very handy if this could be fixed, i.e. drawing a connector with scrolling was made possible.
Of course I know that it is usually advisable to work with several views, but in our currrent project I unfortunately also need one view that contains it all.
