Resize first column of table?
Travis
Post by Travis »
On macOS 15, running Vensim 10.3.2, I can't resize the first column of a table. I feel like this was possible in previous versions of Vensim (10.2?), but not 10.3.x.
I have variables with long names and several subscripts, so I can't see what each row represents because the names are cut off.
Regression? Workaround?
Re: Resize first column of table?
I'm not sure it was possible, but obviously it should be. In the old gui, it was possible to right-click (ctl-click) the table tool to change the default width. Also, the runname should be in its own column. Ticketing for improvement ...
You're right ... as of at least 10.1.5 (Win) it was possible. So, regression ...
Travis
Post by Travis »
Thanks for confirming the regression (I was 99% sure), and opening a ticket quickly.
