I conducted several sensitivity runs changing different parameters and now I want to compare the sensitivity plots but the y axis scale is different. How can I change this to make sure it is the same on all plots so it is easier to compare results?
Thank you in advance.
Best regards,
Oana
Change y axis scale on sensitivity plots
Re: Change y axis scale on sensitivity plots
Unfortunately there is no way to do this at the moment. I'll ticket it for improvement.
