I am encountering problems with the display of legends for the position setting 'above' and 'below' in the MSWindows 2000 OS environment.
The legends only display after a reboot - which I discovered the morning after! - and will vanish again as soon as a new run is recorded.
Any work-arounds available?
Legends display in W2000 environment
Moderator: Administrator
There should be no problems under windows 2000.
Can you send me an example (Tony@ventanasystems.co.uk)
By a process of re-booting I have finalised the layout and configuration of the specific graph - and exhausted my supply of cold beer! As long as I do not effect any change to the layout the legend appears to be permanent where I want it.
When time allows I will try and re-construct the situation in a simple GUI and send it. Thanks meanwhile for the support!
Sorry for the delay!
The legend disappears completely from the frame whenever a dataset is added to the graph - either by adding it using the button command or by inintiating a simulation run.
The legend literally does a disappearing act - it vanishes, even though the graph size is fixed and enough space is available for display.
On re-initiation - with the new dataset included - the legend will be present!
