sable stopped working
Posted: Tue Feb 05, 2013 3:36 am
by kai wang
Hi Tony,
Everytime when I tried to add a graph, sabel just stopped working. Can you please give me some help. Thank you!
Re: sable stopped working
Posted: Tue Feb 05, 2013 9:29 am
What version of Sable are you using?
And do you get a graph appearing on the screen at all, or does it crash immediately?
Posted: Tue Feb 05, 2013 4:29 pm
by kai wang
Thanks for your reply. My Sabel version is 5.1.468.0.
I can add a graph on the screen, but when I try to edit it (open its properties), Sable just stopped working.
Posted: Tue Feb 05, 2013 6:49 pm
I can view the properties ok. Are you selecting a certain property or tab?
Posted: Tue Feb 05, 2013 7:32 pm
by kai wang
Administrator wrote:I can view the properties ok. Are you selecting a certain property or tab?
I can even not choose any property or tab. When I right click the graph and choose property then it died.I attached my model, would you please take a look?
Posted: Tue Feb 05, 2013 8:22 pm
Everything seems fine to me.
Can you explain exactly what you are doing step by step? I mean what buttons you press etc and I'll take the same steps here to try and recreate the problem.
When you insert the graph, do you see a blank graph at all? Or just a hollow box?
Posted: Tue Feb 05, 2013 9:08 pm
by kai wang
Administrator wrote:Everything seems fine to me.
When you open the model, go to the screen of "Result summary_ water resources.VNN". Click on the "graph" button, then a new window get out asking me "New graph type?", I choose "Yes". After that, click on the screen to add a graph, then a hollow box appear on the screen. Right click on this hollow screen and choose "Properties", then Sabel died.
I attached a picture of the problem. Thank you.
Posted: Tue Feb 05, 2013 9:34 pm
ok, it looks like the graph component has not installed properly (the hollow window should show something).
Can you try reinstalling?
Posted: Wed Feb 06, 2013 1:56 am
by kai wang
Administrator wrote:ok, it looks like the graph component has not installed properly (the hollow window should show something).
Hi Tony,
Thanks for your kindly help. I reinstalled Sabel and it worked. Thanks again.
Kai
