Dear all,
I am trying to run a sensitivity analysis where some of the parameter I am using a discrete distribution rather than a continuous one.
for example I want a discrete random uniform distribution in the range [30,60] that select whole numbers only like 32,48,51 etc.
How would I do this for a parameter in a multivariate sensitivity analysis?
Thank you in advance...
YR
Using Discrete Distributions in Sensitivity Analysis
You will need to take the parameters and pass them through the INTEGER function in the model. eg if you had
constant = 1
you would need to have
constant = INIT(INTEGER(constant input))
constant input = 1
then run the sensitivity on constant input. Note the INIT function is just an efficiency thing that prevents the equation for constant from being computed at all times.
constant = 1
constant input = 1
INIT = INITIAL
INITIAL always has to appear first in an equation. I sometimes add an INIT macro to my models, so that I can write things like relativeX = x/INIT(x)
:MACRO: INIT(x)
INIT = INITIAL(x)
~ x
:END OF MACRO:
:MACRO: INIT(x)
INIT = INITIAL(x)
~ x
:END OF MACRO:
Use INTEGER(x*10+0.5)/10
