I am attached a screenshot of a custom graph. I am wondering how to interpret it. By the lines, it appears that jobs are growing at a higher level than people--there are more jobs than people. However, when I look at the left hand side of the graph, I see 100,000 jobs and 200,000 people. So it appears there are more people than jobs.
Can anyone tell me which is correct?
Paul
interpreting custom graph
[The extension rtf has been deactivated and can no longer be displayed.]
If you check the box between variables on the left side of the custom graph definition window you can force the variables to use the same scale. Ordinarily this is only done when units match, but as long as you're OK equating jobs and people it should be fine in this case.
