Somebody help me please!! ramp and pulse train combination
RWTH_FCN
Re: Somebody help me please!! ramp and pulse train combination
Post by RWTH_FCN »
tomfid wrote: Wed Jul 24, 2019 1:16 pm Here's a simple structure that generates pulses. There are a couple limitations - width=TIME STEP, and it wouldn't work with RK4 integration. I'm guessing it would work for your case though.
PULSE TRAIN alternative 1.mdl
In the attached model the pulse function does not work properly. I was wondering, what is the reason.
testmodel.mdl
(13.26 KiB) Downloaded 154 times
data II.cin
(858 Bytes) Downloaded 161 times
Can you let us know which parameter is the problem one, and why you think it is not working properly?
Seems fine to me. Pulse starts at 3 and lasts for 5?
RWTH_FCN
Post by RWTH_FCN »
Administrator wrote: Wed Oct 28, 2020 2:36 pm Can you let us know which parameter is the problem one, and why you think it is not working properly?
Pulse func. Because it does not produce a pulse at time 3.
RWTH_FCN
Post by RWTH_FCN »
tomfid wrote: Wed Oct 28, 2020 3:35 pm Seems fine to me. Pulse starts at 3 and lasts for 5?
I do not see any pulse when I open a graph for pulse func.
Is pulse func in your savelist?
The savelist is probably the problem - I deleted it when I ran the model because it wasn't included, so the results looked fine.
RWTH_FCN
Post by RWTH_FCN »
Administrator wrote: Wed Oct 28, 2020 4:02 pm Is pulse func in your savelist?
No, but I removed the savelist completly and it works now!
If it was not in the savelist, the results from it's calculation would not have been saved. That means no graphs.
