I have a model in which I would like to import data for constants, time series and also arrays.
How can I import data in the case of arrayed variables, where, each of the elements are constants?
Is there a way to do it by the "import" of data in a general way, and vensim finds then the variable in the excel sheet with one that matches in Vensim?
Can I do it through the command GET XLS Constants? What are the differences between the different GET XLS orders?
Many thanks!
S
Arrays - Data import
Re: Arrays - Data import
Two options:
- use changes files
https://www.vensim.com/documentation/cin_files.htm
- use GET XLS
https://www.vensim.com/documentation/fn ... stants.htm
- use changes files
- use GET XLS
