LP Solve Add-on
rcalon
LP Solve Add-on
Post by rcalon »
I am using the LP Solve add-on to build in a market clearing mechanism in a heat model. However, I'm not able to create dynamic inputs that allow me to change the "objective contribution" (marginal costs) over time in the "LP Solve" function. The same limitation prevents me from changing the "upper bounds" (installed capacity) of the function. I was wondering if someone knows if it possible to change the variables in this function over time? Somehow this is not a problem for the 'constraint value' variable. Thanks in advance!
Capacity Allocation with LP.mdl
(3.8 KiB) Downloaded 188 times
Re: LP Solve Add-on
rcalon wrote: Thu Nov 29, 2018 2:01 pmHowever, I'm not able to create dynamic inputs that allow me to change the "objective contribution" (marginal costs) over time in the "LP Solve" function.
Why? What errors are you getting when you change this? They are just constants in the model, there is nothing stopping you from changing them.
rcalon
Re: LP Solve Add-on
Post by rcalon »
Solved, I did not subscript the functions as separate equations.
