'Vec elm map' error
RWTH_FCN
'Vec elm map' error
Post by RWTH_FCN »
I have one constant variable in the model as ‘Wind production as Fraction of Peak’ which it has two subscripts ( day of year ,hour of day). This variable is used in another variable called ‘wind onshore production this hour’ which its formula is as follows:
Wind onshore production this hour[Enduse Region]= vector elm map(Wind Onshore Production as Fraction of Peak[day 1,h1]
,MODULO(hour of year/Hour unit+EndUse Region-1-1,Hours per Year/Hour unit*year unit))
I have changed the format of ‘Wind production as Fraction of Peak’ that it has three subscripts (Enduse Region, day of year, hour of day) right now.
New formula:
Wind onshore production this hour[Enduse Region]= vector elm map(Wind Onshore Production as Fraction of Peak[Enduse Region 1, day 1,h1]
When I run model I encounter this error:
VECTOR_ELM_MAP outside array bounds
I would like to ask you how to change formula, considering new subscript format to fix this error?
Best Regards,
Re: 'Vec elm map' error
I'd start by simplifying things. First of all create a new parameter that is
parameter 1 = hour of year/Hour unit+EndUse Region-1-1
and one that is
parameter 2 = Hours per Year/Hour unit*year unit
Now a 3rd parameter = MODULO(parameter 1,parameter 2)
And see what the value of this is. My guess is that it is lower/greater than the number of subscript elements.
RWTH_FCN
Post by RWTH_FCN »
Administrator wrote: Sat Dec 29, 2018 8:41 pm I'd start by simplifying things. First of all create a new parameter that is
and one that is
Thanks for your response. I created proposed parameters, but I still get same error.
The thing is that in the last model I had 2 subscripts for "Wind onshore production this hour", but I have added one more subscript to it. So, can it be problematic as I have not changed subscript of the formula?
As it can be seen in the picture in left side, there were 2 subscripts and it works, but in right side it seems that adding one more subscript cause that error.
Vec elm map.png (35.08 KiB) Viewed 4263 times
Avoid using the vector elm map function go to
viewtopic.php?f=2&t=3192&p=22055&hilit= ... map#p22055
It is good too setting the use stricte testing in the model<settings<units equiv window
RWTH_FCN
Post by RWTH_FCN »
LAUJJL wrote: Sun Dec 30, 2018 1:30 pm Hi
Thanks for the help. Can you help me how to use "If then else" format like your proposed link instead of Vec elm map for this example:
This is my formula:
Renge of subscripts is as follows:
Enduse Region:1-28
day of year:1-365
hour of day:1-24
Best Regards,
Can you upload your model? I did not realise that "hour of day" is a subscript. It really helps us to help you if you can upload things so we can see exactly what you are doing.
RWTH_FCN
Post by RWTH_FCN »
Administrator wrote: Sun Dec 30, 2018 3:27 pm Can you upload your model? I did not realise that "hour of day" is a subscript. It really helps us to help you if you can upload things so we can see exactly what you are doing.
Unfortunately, I cannot upload the model. However, I have attached the graph and formula of respective part.
As you can see for calculating "Reg WindOn 80m high production this hour" I need "WindOn 80m high production this hour". This variable uses 'vec elm map' function for using data of input(blue variable). In last version, I had only 'day of year' and 'hour of day' as subscripts but I added 'Enduse region' to them(B Region is first region). In other words, I have one input(WindOn 80m high) with 3 subscripts and I am using it in "WindOn 80m high production this hour" with attahced formula. As I have added new subscript to it I think some changes have to be implemented in formula of "WindOn 80m high production this hour" to fix that error.
I would be grateful if you could help me with this description.
There are two difficulties in your formulation.
The first is the correct use of the vector elm map and the possibility to use a simpler formula as explained in the link above or eventually the vector select explained by Tom.
And once you are able to use a simpler formulation of the vector elm map, then try to use it in your specific formulation.
I then propose that you try to get familiar first with my or Tom's formulation with a simple model like the one I explained with the three subscripts and once you are able to built such a model, than it will be time to built the rest of the formula.
See the example joined three_subscripts.mdl.
(2.45 KiB) Downloaded 197 times
RWTH_FCN
Post by RWTH_FCN »
LAUJJL wrote: Sun Dec 30, 2018 5:57 pm Hi
Thanks a lot for your proposed model. I used correct format of 'vec elm map' and it is working now.
