I join a simplistic model with two tables. the essai2 has the datasets named and the other has an *1 for the second table value. if one saves the model and one loads it again, the *1 has disappeared in the essai table, but not the named datasets in the essai2.
Of course, I suppose that you will not find the *1 that i saved, because it has disappeared.
You must just change the dataset for the second value in the table essai into *1, and the table essai will work correctly. But if you save the model and load it again, the *1 will have disappeared and the table essai will no more work correctly.
of course i can use the method with the dataset named, but in my case it was much more convenient to use the *1 formula.
I join a published VPM model that contains the two datasets current1 and current2.
the problem stays the same if you save the model as a .mdl file or in a published way as .vpm
I use Vensim DSS 7.3.5
custom tables do not keep the datasets *1 after the model is saved
- essai.vpm
- (25.89 KiB) Downloaded 179 times
Re: custom tables do not keep the datasets *1 after the model is saved
It seems like this would have no consequence, because by default the first run is shown when no specific name or wildcard is provided.
I had written a reply to this thread, but it must not have posted for some reason.
Can you upload the MDL instead of the VPM please? I can then take a proper look at what is happening.
I join the .mdl file. you will have to create two runs with different value of x and name them current1 and current2, and compare the two graphs essai and essai2.
If I want to use the graph with the *1, I have to modify the graph to include the *1, lost during saving the model, something that is not too cumbersome, but better if corrected.
Best regards.
Best regards.
- essai.mdl
- (1.52 KiB) Downloaded 177 times
