sensitivity analysis (vensim)
RWTH_FCN
Re: sensitivity analysis (vensim)
Post by RWTH_FCN » Tue Oct 08, 2019 3:06 pm
I ran the model on a super computer but since this version does not do any parallel multicore computation, the running time did not reduce. Do you have any plan for releasing that experimental version?
Post by tomfid » Mon Oct 14, 2019 5:24 pm
We're working on it, but I'm not sure whether it'll be done by end of year. The speedup is more than noticeable if you have a many-core machine. Older workstations with 16 or more cores are now readily available at dirt cheap prices. We'll keep you posted as this evolves.
RWTH_FCN
Post by RWTH_FCN » Thu Oct 17, 2019 3:56 pm
Thanks for your information.
RWTH_FCN
Post by RWTH_FCN » Mon Oct 28, 2019 5:12 pm
I did Monte carlo Simulation for a large-scale model, after many simplifications in my model I got this error (it happens at Sensitivity Simulation 1/3):
error writing results-disk may be full
I was wondering is there any solution for it or is it related to size of model?
Post by tomfid » Mon Oct 28, 2019 5:44 pm
Any chance that the disk really is full (or would be, after writing the results)?
RWTH_FCN
Post by RWTH_FCN » Tue Oct 29, 2019 6:47 pm
I don't think so. Maybe it is related to the size of model
Post by tomfid » Tue Oct 29, 2019 7:09 pm
Are you using 32 or 64 bit Vensim? If you do a run with only 1 sensitivity instance (if you can), how big is the file size increment over a non-sensitivity vdf file?
Post by tomfid » Tue Oct 29, 2019 8:41 pm
Actually, I see that the error happens on sim 1. Looking at the code, the counter for writing sensitivity result blocks is an integer, which will impose a 2 gigabyte limit per simulation. Any chance you're near that?
RWTH_FCN
Post by RWTH_FCN » Wed Oct 30, 2019 6:39 pm
I am using 32 bit now. The problem occures when I increase number of iterations. I think your assumption is correct, when size of vdf reaches 2 Gb it produces that error.
Post by tomfid » Tue Nov 05, 2019 3:50 pm
Can you increase the SAVEPER or thin out the savelist a bit? If you're getting gigabytes of output from a one or two simulations, it'll be pretty unwieldy when there are many.
