Graph Shortcuts
Graph Shortcuts
Hi everyone,
Hope this message finds you well. I was wondering whether there is shortcut key for the Graph in the Analysis Tools, so that whenever I select a variable, I can see the graph by pressing that key?
Thank you in advance for your replies.
Best,
Ali
lorenzo.cioni
Re: Graph Shortcuts
Post by lorenzo.cioni »
you can check the "Show behavior" item under the view menu or you can select the desired variable and then left click on the item Graph on the left side of the Vensim main window...
All the best.
Lorenzo
Re: Graph Shortcuts
Hi Lorenzo,
Thanks for your message. Indeed, I knew that but I wanted a faster way to view the Graph. That is why I asked about any possible shortcut key (or at least asking for its implementation in the future versions of the software). But are we sure that there is no other possible ways?
Best,
Ali
Re: Graph Shortcuts
Right-click the graph tool and check Tool Options > Activate on Variable Selection. (However, once that's on, it gets in the way of other tasks.)
Re: Graph Shortcuts
Great! Many Thanks, Tom!
