Vensim v7.3
The scaling modal dialog box, that shows when you open a Windows model file, has the instruction text cut off.
Preferred solution is to handling scaling for the user, and not need this dialog box at all.
BUG: Scaling dialog cuts off text (macOS)
- Screen Shot 2019-07-10 at 1.49.36 PM.png (174.79 KiB) Viewed 1309 times
Re: BUG: Scaling dialog cuts off text (macOS)
We could automagically decide to scale, but if you cycle a couple of times across different display resolutions, integer roundoff errors can accumulate, so it's nice to give the user the option. We could make it a preference rather than I question, I guess.
The diagrams can't be scale-free until we redo the diagram graphics engine (in the works).
