I want to do many simulations, but I have a lot of input data. Is it possible to put them in an excel file (see below) and import them? Can I do one file for all the simulations (not sure it will rename the «simulation results file name» for each simulation) or I need to do one excel file for each simulation (I'll change the «simulation results file name» between each simulation)?
Input data |Simul. 1|Simul. 2|Simul. 3
A |A1|A2|A3
B |B1|B2|B3
C |C1|C2|C3
Thanks for your help
Input data excel import
- Vensim version: PLE
Re: Input data excel import
You can't do this with PLE (from what you describe, you would need DSS).
If a model was made in PLE, is it possible to open it in DSS?Administrator wrote: ↑Mon Aug 05, 2019 8:03 pm You can't do this with PLE (from what you describe, you would need DSS).
Yes
Actually, you might only need Pro.
