Variables in text and sketch views
Phill
Post by Phill »
I have a model that has a large number of 'Views' in sketch mode. I think, some time ago, I must have deleted a view, without removing the variables on it first. Now, when I want to add those variables to a new 'view', I receive an error, saying that the variable already exists. This is quite correct, as I can see them in text mode. I know I can work in text mode, or simply add the same routines to a sketch with different variable names, but I'd be interested to know if there is any way to bring variables and equations that I can see in text mode into a sketch, on to a new, blank, view.
With thanks,
Phill
Re: Variables in text and sketch views
Yes, use the "Model variable" tool on a new view.
It's the 7th tool on the toolbar in the picture at
http://www.vensim.com/documentation/ind ... ?20130.htm
Phill
Post by Phill »
Ah, it's so simple when you know how (or, when you've read the documentation carefully enough!).
Many thanks,
Phill
If you're adding many, you can turn on the sketch varlist: https://www.vensim.com/documentation/sketchlayout.htm
