Graph export at high resolution (>=300 dpi)
mkunovja
Vensim version: PLE+
Post by mkunovja » Sat Aug 31, 2019 5:16 pm
Dear all,
I am a dss user and for a scientific publication I need high resolution images of the graphs created by Vensim.
I can recreate most graphs in Excel or R but with the sensitivity graph this becomes tricky.
There was no real solution in this forum or online elsewhere.
The only way I manage to export graphs in a good quality is print to pdf but I need them in one of the picture formats (png, jpg or the like) with a dpi over or equal to 300 dpi.
Any solutions?
Thank you!
Re: Graph export at high resolution (>=300 dpi)
Post by Administrator » Mon Sep 02, 2019 7:54 am
What do you get if you copy/paste the graph? Vensim outputs vector format graphics to the clipboard so you should be able to get good resolution using copy/paste.
mkunovja
Post by mkunovja » Mon Sep 02, 2019 2:37 pm
That was what I did, copy paste into paint, save it and submit. But that was rejected by the editor of the journal. Then I tried GIMP but there the information from the clipboard is not accepted.
When searching on google this seems to be a common problem, with the only proposed solution being to play around in PowerPoint.
The workaround that I found now was, print to pdf and then convert the pdf to high resolution jpg. This does not deliver perfect results but I hope it will do.
Post by tomfid » Tue Sep 03, 2019 2:12 pm
Pasting into Paint may be your problem. That throws away the vector graphic and gives you some kind of bitmap. Paste into Word, Powerpoint, or a vector drawing program.
