Hi everyone,
Has anyone tried to calculate number of reinforcing or balancing loops passing a specific variable in a system?
I have built a conceptual model and identified some key variables. I now want to check whether reinforcing loops or balancing loops dominate that variable, however there are too many loops involved that variable (~200 loops). It seems impossible to manually count every single loop to identify either reinforcing or balancing for about 5 variables as it will come up about 1000 loops.
Is there any way we can know a loop belongs to reinforcing or balancing without counting everylink relating a variable?
I appreciate any comment or suggestion.
Thanh
Help please-Calculating number of reinforcing/balancing loops passing a variable in VENSIM PLE
Re: Help please-Calculating number of reinforcing/balancing loops passing a variable in VENSIM PLE
You can use the loops tool to count the total number of loops, but not their polarity.
Can you describe your purpose for doing this?
I think what you may really need is eigenvector analysis: https://pdfs.semanticscholar.org/58b4/c ... 845f28.pdf
Hi tomfid, Thanks for your rep.
The purpose of counting number of reinforcing and balancing loops for a particular variable is to identify which type of loop dominate that variable.
Then I can qualitatively assess the system behaviour/stability one I have know dominance loops for key variables.
Should this your company develop an add-on function to VENSIM in the near future?
I could not download the pdf file, could you please re-send it. Thank you
Thanh
Thanh
Unfortunately knowing the number of loops isn't helpful, because many weak loops could be dominated by one strong loop.
You might try this link instead: https://papers.ssrn.com/sol3/papers.cfm ... id=3114407
This is something we're exploring but it's not on the road map yet.
Thank you,
I will read those refs.
