Help - remove lines
wanderbeg
Help - remove lines
Post by wanderbeg »
Hy guys, I need help
How can I remove all these lines from the chart?
Thanks,
Re: Help - remove lines
Presumably you want to remove all but one. :)
Without a legend, it's hard to be sure what this is. You need to do one of the following:
- unload datasets using the Control Panel's datasets tab
- deactivate subscripts using the Subscript Control
- edit the custom graph definition using the Control Panel's graphs tab
wanderbeg
Post by wanderbeg »
Sorry, the lines I want to delete are the background ones.
In a custom graph, change the x-division and y-division settings.
For the graph tool, you can change the global setting on the Scaling tab of the Control Panel.
wanderbeg
Post by wanderbeg »
Helped me
