exporting dataset
Julian.92
exporting dataset
Post by Julian.92 »
is it possible to partially export data from Vensim to excel?
I don't want to export all the results for all subscripts (the whole range), only the results for certain subscripts.
I'm using Vensim Pro 7.3.5.
Hope somebody can help me :)
Julian
Re: exporting dataset
Yes. When you are exporting the dataset, there is a field for "Savelist". This is just a text file containing a list of the parameters you wish to export.
To use, click the savelist button and you will be prompted to enter a filename. Now click the "Ed" button, this will let you select what you want.
Julian.92
Post by Julian.92 »
Ah perfect, thank you! I must have overlooked it somehow.
