Documentation for Delay Information gives false examples
gwr
Post by gwr »
I noted that the online documentation for Delay Information gives the following examples:
The examples SS1 and SS2 are wrong imo: The delay time should step up at time = 40 and thus the delayed input should be held starting at that point in time until more recent information becomes available at time = 40 + 30 = 70 for SS1. Conversely, for SS2, the jump should be at time = 40. Is the documentation up-to-date?
Unfortunately, I am only using Vensim DSS 6.3 occasionally, so I cannot check the most recent release of Vensim. (Vensim DSS 6.3 will exactly reproduce the examples cited above, though, and thus does have a bug imo)
Best regards,
Guido
Re: Documentation for Delay Information gives false examples
I haven't looked at the code yet, but I think there's a method to the madness. The delay is treated like a queue of variable length. When the delay changes duration, it shortens or lengthens the queue, but it doesn't rewrite the existing values. So, values reflecting the new pipeline duration don't begin to appear until a time equal to the change in delay duration has elapsed.
This seems like it might have been a storage-minimizing programming convenience at one time, but I agree that it's a bit bonkers as an operational representation of reality. I'll look into an upgrade. This would probably require a different function.
This has not changed in 8.0.6.
gwr
Post by gwr »
Thanks, for acknowledging the false behavior, Tom - not everybody does. ;-)
Writing information delays with variable delay times is tricky imo: Holding the information we have when the delay time increases (delayed information will then be older than what we already know) makes the implicit assumption, that we are aware of the increase in delay time. That assumption may not always hold and thus I find that a strict formulation, e.g a Delay Fixed with variable delay time that will have a step down in the example SS1 may also make sense in some situations.
gwr wrote:
Wed Nov 13, 2019 8:00 pm
Hey, no politics in the forum! ;-)
In Ventity, the equivalent function has access to the full time series history of the input, and therefore when the delay changes, it simply (instantaneously) shifts the lookup to a different point.
I think the key question here is, what real-world phenomenon are we trying to represent? The Ventity version makes sense for something like a change in the reference point for some value, due to a change in administrative rules. The Vensim version would have to be something more arcane, more like an increase in the speed of postage, causing newer letters to begin overtaking older ones.
gwr
Post by gwr »
Why not have both versions? I just decided to have both versions using Modelica (where changes are also instantaneous as events per definition are not consuming time).
Let’s assume, that you are looking at stock information and all you can see is the next tick - but you never see what time it is from. If the time for reporting changes, you may note a discontinuity, but you also may not. All you see is stock values, that all of a sudden are older (or younger) than those you had before - without you knowing.
On the other hand, were I to write letters containing information (or e-mail) you would know, when the letters are older or younger from the time stamp on the envelope - so you keep the one with a later time stamp.
This is a bit constructed, but it carries the point, that there may well be reasons for perceiving or not perceiving a time stamp together with the information received.
gwr
Post by gwr »
To make this self-contained:
The correct outputs (at least correct with regard to the behavior that should be expected from reading the Delay Information documentation) for the examples given in the documentation are:
Interestingly, I got the following message from Tony Kennedy when I at first approached him via e-mail:
The sample model that ships with Vensim is behaving as expected.
I downloaded the Delay Information.mdl from the website and found, that it is still the same as the one that shipped with Vensim DSS 6.3 and has the following structure:
Here the input variables would be defined as follows (in Vensim):
delayTime= WITH LOOKUP (
	Time,
		([(0,0)-(100,20)],(0,10),(20,10),(30,20),(60,20),(70,10),(100,10) ))
	~	Day
information=
	RAMP(1, 0, 100)
	~	boxes/Day
Please check for yourself, whether the Vensim output that "shipps with Vensim" really is matching the following output:
The model output from Vensim DSS 6.3 certainly is not "behaving as expected"... ;-)
