Hello & Top of the day everyone,
i have this problem where i want to model my electricity supply industry market but i have issue with time bound setting for the model setting
for the overall model, it supposed to be in a yearly time setting, but throughout the calculations, there are some parts that needs hourly setting.
I really need some enlightment from any of you.
Thank you in advance
Time Bound in Model Setting
Re: Time Bound in Model Setting
I'm not sure exactly wray you are asking for help with.
If you want to change the x axis, take a look at the time base function. This leaves the model running in years, but you can display graphs using hours on the x axis.
I know my question is not that clear. Sorry for that.
OK the problem is this. So, the whole set of the model has to be in yearly setting 'cause i basically want to make it a planning model.
But only at the "Wholesale Market" box, the calculation in it, has to be done base on hourly calculation.
So, do i have to make 2 models, and merge it OR is there any other way?
If let say i have to make 2 separate models for the whole model and also the "Wholesale Market", how do i merge the 2 models?
Again, thanks so much in advance.
You guys' helps are much needed.
p/s: photo credited to owner.
Administrator wrote: ↑Sun Feb 02, 2020 2:45 pm I'm not sure exactly wray you are asking for help with.
I guess this one is something that i can look into.
Thankss!!
Thankss!!
Tried this one, but i couldn't relate
Attached is my file.
Please someone help me.
- Load Demand Curve.mdl
- (3.05 KiB) Downloaded 168 times
It will be easier for anyone to hep you if you correct first the unit errors in th model uploaded, a fundamental basic of SD.
Regards
Regards
Sorry i didn't realise that i uploaded the wrong file.
Tbh, i am very new with this Vensim. Hence kinda lost with it.
