Lookup tables in SyntheSim
I recently created a version of the Car Lot model in Meadows' Thinking in Systems, in which I specified customer demand as a Lookup table so that I could see the effect of different temporal patterns of customer demand. Everything works fine, but when I use SyntheSim and modify the values for customer demand by grabbing points on the graph and moving them, I see a whole series of lines (see attachment). The table shows the points for the "final" line, and if I close the window and then re-open it, only the "final" line appears. This is a bit annoying to do this, though. Is there any way to get rid of all of those "intermediate" lines without having to close and re-open the window? (Note: this also happens when using SimSetup).
- LookupSyntheSim.png (56.77 KiB) Viewed 1138 times
Re: Lookup tables in SyntheSim
p.s. I am using a Mac running Catalina and I find this in both VenSim PLE and VenSim Pro
