using IF THEN ELSE for creating max/min values
alliecase
Post by alliecase »
I know this is a similar post to one that discussed how to create multiple IF THEN ELSE statements/also using LOOKUP functions, but I haven't had success with the solutions proposed yet. I have a sine wave that I am using to create a pattern of mortality rates. I do not want the mortality rate to reach above 1.0, or go below 0.148. Individually, these equations work:
IF THEN ELSE(((sine wave*0.13852)+0.28775) < 0.148 , 0.148, (sine wave*
0.13852)+0.28775)
IF THEN ELSE(((sine wave*0.13852)+0.28775) > 1.0 , 1.0, (sine wave*
0.13852)+0.28775)
However, trying to add them together creates some kind of compounding effect/does not seem to model properly. Would a look up function work better? I already have an established working function, again just trying to set a max and min value basically. Thank you so much for any input. Happy to attach my .mdl file if that helps.
Re: using IF THEN ELSE for creating max/min values
Will the min or max functions work?
For example,
value = max ( 0.148, min ( 1, sine wave ) )
alliecase
Post by alliecase »
Administrator wrote: Fri Apr 03, 2020 8:46 pm Will the min or max functions work?
For example,
Doing this resulted in the proper boundaries, but removed the sine wave increasing in amplitude over time. The sine wave will not hit these bounds until timestep = 50 or 60 years and the function is increasing in amplitude over time.
alliecase
Post by alliecase »
I also tried nesting again this morning, with an error that I'm expecting an operator.
IF THEN ELSE(((sine wave*0.13852)+0.28775) <= 0.148 , 0.148, IF THEN ELSE(sine wave*0.13852)+0.28775) >= 1.0 , 1.0, (sine wave*0.13852)+0.28775)))
It's probably a parentheses nesting problem.
It's better if you make the sin wave a separate variable, then clip it in another equation. Also, the parameters should be made into variables so that units balance.
For example:
sinwave = amplitude*SIN( (Time-PhaseShift)/period*2*3.1415926 )
clippedSinwave = MIN( xmax, MAX( xmin, sinwave ) )
alliecase
Post by alliecase »
tomfid wrote: Wed Apr 08, 2020 4:49 pm It's probably a parentheses nesting problem.
For example:
Nesting the function with proper parentheses worked. Thank you very much for the help.
