Using data from the previous time // Vensim PLE
wlisses
Post by wlisses »
To calculate the value of an auxiliary variable I need its value in t-1, i.e, its value in the previous period.
For example, the variable is speed.
I created the variables "speed (t)" and "speed (t-1)", where
Speed (t) = Speed (t-1) * EXP (0.034 * (Variable z - Variable y)) and
Speed (t-1) = IF THEN ELSE (Time = 0, 9758, GET DATA AT TIME(Speed (t), Time-1))
Thus, the initial speed is 9758, that is, the value at time = 0. In addition, the speed for time > = 1 will be calculated based on the speed of the previous time. However, the GET DATA AT TIME function is not available in the Vensim PLE.
Therefore, I need to find a way to assign an initial value to an auxiliary variable and calculate its value in the following periods using the value of that variable in the previous time (t-1).
Does anyone have any suggestions on how to do this in VENSIM PLE ??
Thanks in advance,
Wlisses.
Re: Using data from the previous time // Vensim PLE
GET DATA AT TIME is for getting data from external data files, not from the current simulation.
You can use DELAY FIXED to get the value of a variable at a previous time step. The delay time will be "time step".
Looking at this equation, I see several other problems. For one thing, the constant .034 is embedded with no obvious interpretation, as is 9758. Unless the variables are dimensionless, this won't pass a units check.
https://metasd.com/2019/11/seven-deadly ... structure/
I would suggest a more physical model, like:
Acceleration = f( variables, parameters )
Speed = INTEG( acceleration, initial speed )
Initial speed = 9758 ~ units?
wlisses
Post by wlisses »
Administrator wrote: Tue May 19, 2020 1:54 pm GET DATA AT TIME is for getting data from external data files, not from the current simulation.
Thanks!!!!
wlisses
Post by wlisses »
tomfid wrote: Tue May 19, 2020 2:42 pm Looking at this equation, I see several other problems. For one thing, the constant .034 is embedded with no obvious interpretation, as is 9758. Unless the variables are dimensionless, this won't pass a units check.
Thanks!!!!
wlisses
Post by wlisses »
Hi Tomfid.
I still have some problems. Can you help me?
The traffic congestion variable is dimensionless and it is calculated using other variables from the model.
I'm still working in the relationship between congestion and speed (speed formula). However I think I'm using the delay fixed function in a wrong way.The initial value for speed and number of accidents is 40 and 10000, respectively.
The adopted equations are:
Speed = IF THEN ELSE(PREVIOUS TRAFFIC CONGESTION/Traffic Congestion < 0.95, Previous Speed*1.02 , Previous Speed )
Previous Speed = DELAY FIXED(Speed, 1 , 40 )
DELAY FIXED( Traffic Congestion , 1 , 0 )
Previous number of accidents = DELAY FIXED(Number of Accidents, 1 , 10000 )
Number of accidents = Previous number of accidents*EXP(0.034*(Speed-Previous Speed))
IMAGE:https://ibb.co/tZ3wf1v
It would be easier to upload the model. Posting equations and an image means we need to spend precious time replicating it in Vensim.
Before uploading, remove the numbers from your equations and assign them to separate Vensim constants. For example, what is 0.95? Create a constant, give it the value 0.95 and correct units. We have no chance of understanding a model with embedded constants unless they are completely obvious (for example, 3.14).
wlisses
Post by wlisses »
Administrator wrote: Wed May 20, 2020 10:24 am It would be easier to upload the model. Posting equations and an image means we need to spend precious time replicating it in Vensim.
Hi, I made the changes.
I am sending the model. I want to understand the use of DELAY FIXED to get the value of the variable in the previous period.
The variable "number of accidents" must be 10000 at time=0. The speed starts with 40 km/h.
The model:
https://www.dropbox.com/s/2pfqusvs7s21n ... l.mdl?dl=0
You've initialized "previous speed" to 0. Initialize it to "speed" or 40 and it should work.
However... it won't be a good dynamic model. I'm guessing that this is a replication of some kind of regression study, in which someone took the underlying physics of the situation, differentiated and discretized time. That might be necessary for using some stats package, but it would be better to have a more physical model.
For example:
congestion = ...
speed = INTEG(acceleration, init speed)
acceleration = f( congestion )
accidents = g( speed, congestion )
The current formulation with accidents = f( previous accidents, acceleration ) is really unphysical.
Also, all parameters should be made into explicit variables with assigned units. This includes dimensionless parameters, because they should be exposed to sensitivity analysis, documented and consistent if used more than once. The only exception is things that are invariant or definitional, like 1 or pi.
