Hello mates,
I have one question.
How can i change the layout of my model from text to sketch view?
Tried to do it through the VIEW tab, but still couldn't get it into sketch view.
Change view from text view to skecth view
Re: Change view from text view to skecth view
Do you get a syntax error when you try to switch? If yes, what is it? Or can you upload the model or show us where the error is?
Yes....i do get a syntax error.Administrator wrote: ↑Wed Sep 09, 2020 12:40 pm Do you get a syntax error when you try to switch? If yes, what is it? Or can you upload the model or show us where the error is?
I'm afraid i can share this model because it's not mine. But the syntax error written is "missing a closin paranthesis on a lookup table call".
And it happened that the cursor is at this part of the model
Pink Noise Maker=
RANDOM PINK NOISE( 1, 0.1, 1, 1234 )
~ Dmnl
That looks fine to me. Do you have RANDOM PINK NOISE defined as a macro?
What parameter follows this one in your Vensim file? Maybe the syntax error is with the next variable.
