Venapp Error With Vensim Pro 8.0.9
Chaboud Christian
Post by Chaboud Christian »
Good Evening
I just receveid a new licence for Vensim Pro 8.0.9
I have a problem using Venapp whcih where OK with older vensim versions.
For instance when I try to load the Venapp " template " supplied with the vensim samples models (supplied with this vensim release), after loading the Venapp and using the command File>Run Venapp i get a strange error message :
"Do you want to treat this as input Data ?" without solution.
A second problem for me is that the command File>Open model doesnt still allow to open Venapp Files (*.cvd) as
it was possible in older vensim releases ... the only way I find to open Venapp file was through the file editor ...
is it the good way to open Venapp ?
I am a very old vensim User quite disturbed with these problems with this release ...
Thanks in advance for your rapid Help !!!
Sorry for the pretty poor english
Re: Venapp Error With Vensim Pro 8.0.9
Venapps only work with Vensim DSS, not Pro.
