Good Evening
I just receveid a new licence for Vensim Pro 8.0.9
I have a problem using Venapp whcih where OK with older vensim versions.
For instance when I try to load the Venapp " template " supplied with the vensim samples models (supplied with this vensim release), after loading the Venapp and using the command File>Run Venapp i get a strange error message :
"Do you want to treat this as input Data ?" without solution.
A second problem for me is that the command File>Open model doesnt still allow to open Venapp Files (*.cvd) as
it was possible in older vensim releases ... the only way I find to open Venapp file was through the file editor ...
is it the good way to open Venapp ?
I am a very old vensim User quite disturbed with these problems with this release ...
Thanks in advance for your rapid Help !!!
Sorry for the pretty poor english
Venapp Error With Vensim Pro 8.0.9
Re: Venapp Error With Vensim Pro 8.0.9
Venapps only work with Vensim DSS, not Pro.
