I need help in solving this issue. I tried to make a simple model with 2 subscripts, both function of time (vector lookup) . I could solve the model without any error (see model test vector-OK.mdl) and got the results as I expected. However when I add another auxiliary as multiplier (this could be used later in my model as initial point), I got error message "floating point error..". I checked the model using Check Model feature and it says "Model is OK". I searched similar problems in this forum but couldn't find it. Any help is really appreciated.
Thanks so much
floating point error in vector lookup and subscript
- TESTVECTOR-ERROR.mdl
- Model with error message
- (2.04 KiB) Downloaded 136 times
- TESTVECTOR-OK.mdl
- Model OK
- (1.85 KiB) Downloaded 143 times
Re: floating point error in vector lookup and subscript
Try changing
R0[shrimptype] * VECTOR LOOKUP(RECVALUE[shrimptype,timedim],Time,INITIAL TIME,FINAL TIME,0)
to
R0[shrimptype] * VECTOR LOOKUP(RECVALUE[shrimptype,T1],Time,INITIAL TIME,FINAL TIME,0)
It's would also be a good idea to remove the call to VECTOR LOOKUP and put it in a separate equation to help with debugging.
to
Dear Admin..
Thanks a lot..!! that's awesome.. it works now. Thank you so much helping for solving my problem
