Hi everybody
is there any way to use, in a Vensim model, a variable that simulates a truncated lognormal? I know how I can simulate a "full" lognormal through a normal distribution but what about the insertion of a maximum positive value? How can I rescale so that the area under the truncated disribution is still equal to 1?
All the best, thanks in advance for any suggestion.
Lorenzo
Truncated lognormal
- Vensim version: PLE
Re: Truncated lognormal
The RANDOM NORMAL function generates a truncated Normal distribution, so if you transform that you'll get a truncated Lognormal. You could do something like:
randx = EXP( RANDOM NORMAL(-something large, LN(max val), LN(geometric mean), geometric SD, stream ID) )
Hi tomfidtomfid wrote: ↑Sat Oct 17, 2020 2:03 pm The RANDOM NORMAL function generates a truncated Normal distribution, so if you transform that you'll get a truncated Lognormal. You could do something like:
thank you a lot... fast and precise as usual
All the best.
Lorenzo
Hi tomfid
is it the same if I use this form?
randx = EXP( normal_mean+normal_std_dev*RANDOM NORMAL(-100, LN(max val),0, 1, 0 )
Lorenzo
Lorenzo
Yes, as long as LN(max val) represents the maximum departure in terms of number of geometric std dev above the mean.
Hi tomfid
could you be more clear about this: "the maximum departure in terms of number of geometric std dev above the mean"?
Indeed I have to generate a lognormal whose normal parameters are μ = −13.3 and σ = 3.49 truncated on the interval [0, 2.35 × 10−3]).
Lorenzo
Lorenzo
That would be:
EXP( RANDOM NORMAL(-100,-6.05,-13.3,3.49,stream) )
where -6.05 = ln(2.35e-3)
The -100 is just a big number (30 standard deviations roughly) - the truncation at 0 isn't really needed since the lognormal is always >0.
Hi tomfid
thank you a lot.
All the best.
Lorenzo
