importing data
importing data
Where can I found desription/manual of (model ; import datasets ) DATA IMPORT SETTINGS and how the settings correspond to the EXCEL file configuration, especially with 2-3 indexes.
WS
WS
Re: importing data
The help system has lots of info about importing datasets.
If you can upload an example of what you are having trouble with, we can take a look.
Re: importing data
Helpis not very helpful, for example doesn't mention that when you import subscripted data, VENSIM does not read the subscripts, but assignes data to the vector or matrix in declred subscripts order.
I have actually problem with importing subscripted data. I'm struggling with it all last two weeks.
The attached xls file has the data, that was impotred to dat.vdfx file with no error:
Writing 8 values for HEATING MODE GENERAL OLD[URBAN,CENTRAL HEATING INDIVIDUAL]
Writing 8 values for HEATING MODE GENERAL OLD[URBAN,DISTRICT HEATING]
Writing 8 values for time base -Time
Loading Dat.vdfx as Dat.vdfx. Origin is ..
DatXLS.xls converted to dataset Dat.vdfx on Wed Nov 4 13:40:41 2020 (not possible to attach)
Dat.vdfx was declared as data set im Model simulation menu, but the result is:
WARNING: No data found for -HEATING MODE DETAIL 0[URBAN,STOVE,RES]- in the exogenous data files.
WARNING: No data found for -HEATING MODE DETAIL 0[URBAN,STOVE,BIOMASS]- in the exogenous data files.
WARNING: No data found for -HEATING MODE DETAIL 0[URBAN,STOVE,HEAT PUMP INDIVIDUAL]- in the exogenous data files.
WARNING: No data found for -HEATING MODE DETAIL 0[URBAN,STOVE,ELECTRICTITY]- in the exogenous data files.
... similar warnings suppressed for additional variables
ERROR: Unable to correctly load in exogenous values - aborting.
I looking for any help or detailed description of importing data, or other possibilities of using such data.
Best regards
WS
Best regards
WS
Re: importing data
Have you clicked on Model->Simulate->Advanced and added the data to the model using the "Data sources" button?
Re: importing data
Shure it is marked, see the attached file.
- screen.png (85.05 KiB) Viewed 3577 times
Re: importing data
ok, I cannot see what the problem is here. Vensim is reporting that it cannot find certain data which is correct as it is not in the spreadsheet you are importing.
Re: importing data
The GET XLS and GET DIRECT functions read data in the declared order of subscripts.
Data imported via the menu or command script functions (TAB2VDF, etc.) does read the subscripts. If you have data that is not populated for all elements, this is usually the preferred way to handle it.
Re: importing data
This seems to work OK for me. The import succeeds and the model runs. I do notice one glitch, which is that the xls file is in Excel 2 format (truly ancient), and the import misses the last column of values. I resaved the file as tab-delimited text and it works fine. Modern XLSX would probably also work fine.
The puzzle here is why you're getting an abort, rather than just warnings about data that really is missing.
Re: importing data
Anyway, this works:
Re: importing data
Thanks for help.
Your files work, with missing data warnings and without abort.
Re: importing data
The abort is baffling. If you zip your package with the vdfx and upload it, we can investigate.
Re: importing data
I followed your reccomendations, and now I can manage the data import. Many thanks for the help.
WS
WS
