Vensim no longer reading in custom graphset, even when .mdl and .vpmx have been saved with the graphset selected
Upon updating to 8.1.2 today, I now have to manually reload the custom graphset every time I launch a mode, even when the graphset was previously opened and saved. It may be a combability issue in that versions of our software are developed on a pre-8.1.2 build and Vensim no longer recognizes the saved graphset.
Re: Vensim no longer reading in custom graphset, even when .mdl and .vpmx have been saved with the graphset selected
Do you have reform/clean on save enabled?
I'm not sure - where would I see this option? I don't see it in Tools>Options
Not to worry, I think I've found the issue and working on a fix.
It's a checkbox in the Model>Reform&Clean dialog.
It's a useful feature if you're using version control, because it preserves alphabetical order of equations (generally diff tools don't understand nonprocedural languages).
