hi,
I'm using Vensim PLE. My model works fine but every time I run a simulation a get the following error message: Unable to open the file ReferenceMode.
Floating point error computing - Customer order rate - at time = 1.500000
thanks for your help
Missing reference mode and floating point error
Re: Missing reference mode and floating point error
You can suppress the Reference Mode warning by going to Model>Settings>Ref Mode and deleting any entry in the list. (It's possible to create a blank reference mode by inadvertently hitting the tool.)
The floating point error indicates a problem with your Customer Order Rate equation - usually a division by zero. Examine the equation, and each of its inputs to detect the problem.
