Sample model “SAMPLE IF TRUE” not working
Posted: Sun Feb 28, 2021 4:47 pm
Hi everyone,
I would like to run this sample model:
http://vensim.com/documentation/Models/ ... 20TRUE.mdl
However, I receive a warning after running the model:
“WARNING: ACTIVE INITIAL differences found. Use Options>Setting to control reporting. “
I tried to find the settings to control the reporting. Could anyone of you please help me finding it?
1.
This post was not helpful, because the toolbar/menu struture changed (my assumption).
viewtopic.php?t=5477
2.
I found something similar, the “active initial” settings here:
Model –> Settings: In the bottom section “Active Initial”
Sadly, changing “Relative” and “Absolute” does not change anything or reduce the number of warnings.
I know, that SAMPLE IF TRUE following the documentation is not meant to be available in PLE.
Maybe my inability to switch of the warning is connected to that?
Thanks a lot for your help. It’s highly appreciated!
Fred
1.
2.
Fred
