use superordinate folders in relative file paths for vensim command scripts?
Posted: Wed Mar 31, 2021 10:53 am
In a command script the relative file paths can use sub-folders by using a forward slash "/"
This works well.
Is it also possible to go a level higher to a superordinate folder? Let's say I have a folder wich contain my command scripts that is a subfolder to a folder which contains an excel file and I want to import that excel file.
Is the only way to temporarily copy the command script to the superordinate folder containing the excel file or can I somehow indicate that in the path?
I have tried ../ or ..\ but that does not seem to work.
Kind regards,
Max Kleemann
This works well.
Kind regards,
Max Kleemann
