Lookup for time series
- Vensim version: PLE
Hello. Am new to vensim and have been trying to simulated the population model of my country. I wish to input the birth rate and death rate data as Lookup tables(given that they are time series data), but haven't been able to do so. Any suggestion will highly be appreciated. Thank you
Re: Lookup for time series
Can you explain why you haven't been able to do what you need? What errors? Can you upload your model so we can see what you have done so we can point you in the right direction?
1. The Help system has a lot of material on lookups. https://vensim.com/documentation/usr08.html
2. Quick start video: https://vimeo.com/55318481
Thank you for your quick response. I have attached the model here. I will love to input time series data for the birth rate and death rate using a lookup table. The birth rate and death rate values vary each year.
Thank you.
Thank you.
- population model.mdl
- (3.82 KiB) Downloaded 118 times
- lookup.PNG (4.07 KiB) Viewed 1257 times
