I have two different files with '.out' kind that contain two sets of calibrated constants values. I want to combine and use as one file in order to run a sensitivity analysis for my model.
Can someone advise please?
How to combine two .out files?
- Vensim version: PRO
Re: How to combine two .out files?
You can load both of them, or edit using a text editor and copy/paste the contents of one into the other.
It worked well, thanks.Administrator wrote: ↑Thu Sep 23, 2021 6:32 am You can load both of them, or edit using a text editor and copy/paste the contents of one into the other.
