installation error
meng333
installation error
Post by meng333 »
Hi there,
I'm writing to see if you can help me with Vensim PLE installation. We have a study group and we tried to install PLE version on individual computers. Recently (probably after September), we found that there was always an error (see below) while running the installation package.
“Resource file comes from a different version of Vensim(002)”
It worked well before September 2021.
I looked up the information on this Vensim forum platform and found a similar post here:
viewtopic.php?f=2&t=7789&p=30056&hilit=002#p30056
So, we followed those steps you suggested there but it failed.
I'm wondering if you can take a closer look and check if the installation package is still workable. Not sure if there is any update needed to deal with this issue.
Thank you so much for your time! Appreciate your help!
Re: installation error
Have you tried the latest version? 9.0.1 is available for download at the moment.
meng333
Post by meng333 »
Got it. Could you please confirm if the link is correct for downloading PLE?
https://vensim.com/free-download/#ple
In the table there, I didn't find the check box of 9.0.1 version to check off.
I'm not quite sure if there is there another link I can refer to.
Much appreciated.
It'll give you the latest. The 8.1/10 indicated on the form is the Windows version requirement.
Download the Windows x64 version, it will be 9.0.1.
chenho
Post by chenho »
Administrator wrote: Fri Oct 15, 2021 5:50 pm Download the Windows x64 version, it will be 9.0.1.
Hi there!
I got the same problem as meng333. I have installed the latest 9.0.1 version, but the same errors still pop up(error 002 and 997)
"Reinstall Vensim(997)"
My PC is window 10. I have tried all the versions provided on the official website, and installed them with administrative permissions, the same error still occurs. It has been several weeks. I am really anxious because it's part of my assignment in university. Would you give me some suggestions to solve it?
Many thanks for your time in advance! Appreciate your help!
I've just tested here and it installs and runs without problems.
1. What browser are you using?
2. Are you saving the installer to disk before running it?
3. Do you have Vensim open when trying to install it?
4. Is it possible you are running an old installer that you downloaded before?
You can also try opening Windows file explorer and pasting in
%PUBLIC%\Vensim\PLE
There should be some files there (with extension .vrf), delete them and try installing again.
chenho
Post by chenho »
Administrator wrote: Tue Oct 26, 2021 10:53 am I've just tested here and it installs and runs without problems.
Thank you! I am using google browser. I have downloaded the installer to disk C, and installed Vensim there. At the first time when I downloaded it, that two errors were occur then, and I have never downloaded Vensim before...
I have also tried to delete all the documents in PLE, and reinstalled it. But the same error still occurs...
I wonder are there any other ways...
It's really nice of you to answered me so detailed. Thanks again! Sorry to bother you so late, but I just can't help it..
chenho
Post by chenho »
Administrator wrote: Tue Oct 26, 2021 10:56 am You can also try opening Windows file explorer and pasting in
%PUBLIC%\Vensim\PLE
I wonder Is it possible that you send me the whole installed Vensim documents directly by email, and I copy them to my computer?
Many many thanks!!
chenho
Post by chenho »
meng333 wrote: Fri Oct 15, 2021 3:57 pm Hi there,
Hello!
Have you solved that problem? I also encounter the same one...
Thank you~
Can you zip and upload the file en09000100.vrf from your computer? It will be in C:\Users\Public\Vensim\PLE.
chenho
Post by chenho »
Administrator wrote: Tue Oct 26, 2021 8:05 pm Can you zip and upload the file en09000100.vrf from your computer? It will be in C:\Users\Public\Vensim\PLE.
Sure, I've uploaded it. Thank you!!
en09000100.zip
(198.93 KiB) Downloaded 656 times
HXJZ
Newbie
Post by HXJZ »
hi, have you solved this problem ?
I encountered it as well after changing my SSD.
When you install, what user names are you using?
If you save the attached zip file to
and unzip, hopefully PLE will now work for you.
Please let me know what username you are using when installing though in case that causes a problem.
en09000100.zip
(190.51 KiB) Downloaded 680 times
chenho
Post by chenho »
Administrator wrote: Wed Oct 27, 2021 12:24 pm If you save the attached zip file to
Hi! It works! Thank you!! You are my hero, hahahaha!!!
I used the name that I input when downloading it from the website.
chenho wrote: Wed Oct 27, 2021 12:42 pm I used the name that I input when downloading it from the website.
Can you let me know what that was exactly please? Did it contain any non-ASCII characters? I'm trying to work out why it is not working for you.
chenho
Post by chenho »
Administrator wrote: Wed Oct 27, 2021 12:52 pm
Ok, it's Ho Chen, there's a space in between
Ivan Lee
Post by Ivan Lee »
I have the same problem, but i install it(PLX 9.0.1) on Win11 OS. I uesd the Zip file(en09000100.vrf) that you uploaded here, it works now.
So why i use the new file en09000100.vrf to replace the old one, then it works?
Ivan Lee wrote: Mon Nov 15, 2021 12:49 pm So why i use the new file en09000100.vrf to replace the old one, then it works?
I don't know. For some reason, certain machines do not run the installation properly. And we have been unable to find out why this is. And even though I've asked users in this thread for information, they have not replied.
If you can let me know what language your operating system is, that might help.
Ivan Lee
Post by Ivan Lee »
Administrator wrote: Mon Nov 15, 2021 1:01 pm
My personal computer language is Chinese, and use Chinese full spell mode,and the computer operation system is Windows 11.
The same installation package in my office computer is OK which the operation system is Win10. but,in my personal computer is NOK which the OS is win11. I don't think the reason is due to the operation system different,because i see the problom also be happened on the computer which have the win10 OS.
Ivan Lee
Post by Ivan Lee »
Another question is, what is the difference between the default file "en09000100.vrf" and the new one you gave us to replace it.
Is your office computer in Chinese?
Ivan Lee
Post by Ivan Lee »
Administrator wrote: Mon Nov 22, 2021 2:34 pm Is your office computer in Chinese?
Yes.
