I am developing several programs that run a .VPM file via a Webservice interface. When I run the webservice and find an error in the underlying model, I am unable to republish the .VPM file. Basically the webservice seems to keep it locked up.. Is there any way I can unlock the file without restarting my computer. I did try stopping and restarting IIS ( I am running the webservice on a local machine), but that did not seem to work... Would be grateful if anyone has ideas
Phil
problems with VPM file being locked
This is for the multicontext version. To make sure a .vpm file is not in use in a single context open a different .vpm file (actually any 1 context using a .vpm file would lock it).
Alternatively you can either restart the web service or use LoadLibrary/FreeLibrary instead of linking with the .lib file for the Vensim DLL and be sure that FreeLibrary is called.
