I'm trying to create a published version of my sable project. When I open the spk file, the bits of the project which use scripts won't work. Can I fix this?
Thanks,
Kate
Publishing Sable
Moderator: Administrator
The original file is too large to attach so I removed most of the screens and script to just leave one example screen and hopefully make it small enough to attach. However, when I publish this version, the scripts work! Is it possible the problem is something to do with the file size?!
I can send through the original script files I've been using although seeing as these work in the non-published version I don't know if they're causing the problem.
Kate
[Edited on 6-7-2010 by KateCN]
Kate
I really need one that doesn't work so I can figure out where the error is.
You can email me direct at tony@ventanasystems.co.uk.
