Working with Venapp
Working with Venapp
I am building a game using Venapp but I have some problem hope u can help:
1- LISTVAR,"FINAL TIME",88,24,7,4,L|System|10|B|255-0-0,[0|60]10|20|30|40|50|60,,
I still got error that the listvar is empty so what is the problem?
2-MODVAR,"Number of new students",17,12,6,5,L,[0|5000|2000],"
still give me error
but the Idea for both error that when I test screen it works perfectly but when I run Venapp it give me error??
so I need some help....
still give me error
Final time, by default, is a constant. I suspect that Number of students may also be a constant. Once you execute MENU>GAME you can only change Game variables. So you will need to split the setup part of the Venapp from the ongoing gaming changes. A standard approach is
game input = GAME(constant input)
change constant input before entering game mode, then change game input.
Is that what u mean ?
:SCREEN NAMERUN
SCREENFONT,Times New Roman|10||0-0-0|-1--1--1
COMMAND,"",0,0,0,0,,,SIMULATE>RUNNAME|?Name for new game output
COMMAND,"",0,0,0,0,,,GAME>GAMEINTERVAL|0.25
COMMAND,"",0,0,0,0,,,MENU>GAME|O
CLOSESCREEN,"",0,0,0,0,,,,GAMEINI
:SCREEN GAMEINI
TEXTONLY," G A M E C O N T R O L S",61,2,33,8,C|Times New Roman|16||125-50-75,,,
BUTTON,"Start",62,12,7,5,L,Ss,,MAINGAME
RECTANGLE,"",71,12,7,5,L|Times New Roman|10||75-125-55,,,
TEXTONLY," End ",72,13,5,0,C|System|10|B|75-125-55,,,
BUTTON," Exit ",85,12,9,6,L,Xx,,ASKEXIT1
TEXTONLY,"Set Final Time",79,25,8,0,L|Times New Roman|10|B|255-0-0,,,
TEXTONLY,"Current Time",63,24,8,0,L|Times New Roman|10|B|0-0-0,,,
SHOWVAR,"TIME",72,24,4,0,L|System|10|B|255-0-0,,,
:SCREEN NAMERUN
:SCREEN GAMEINI
... but you can always change the type of your constants to GAME variables in the equation editor, as needed.
... or in the equation editor, set the variable type to "auxiliary" and the subtype to "gaming".
Do you want to email it to me direct (tony@vensim.com) and I'll take a look?
